Originally posted by: kindest
i saw in other thread you said its louder then your 120mm fans?
that is nuts dude. mine isnt loud at all but i did see it runs at like 6000rpm.
have you tried hooking it to a fan controller and turning it wayyy down.
Originally posted by: scoobydoo
I've put a Zalman NB cooler (the blue one). However, I've only got an Asus X300 there and so they coexist together, but it's still a bit of a tight squeeze. Luckily, the Zalman can be adjusted a little. There's about 3/4mm of clearance between the two.
Running at the lowest volts (1.5v), it still gets very hot. I don't know the temperature. Whacking up the setting to 1.8v, it gets too hot to touch!
Originally posted by: plantier16
My fan is loud as well. Can it be disabled without causing problems?
Just installed a Zalman Fanmate 2 fan controller and lowered the NB fan speed so see what worked best. It is almost silent at 3000 - 3500 rpm. Monitored the NB temp and it's consistently 10 - 18 C.
Originally posted by: pickle965
Just got my MSI Neo4 Ultra rig together. The chipset fan does seem a bit noisy, but then again it runs at over 7300rpm. I noticed in Nvidia nTune and MSI CoreCenter there is no reading coming up for the northbridge/chipset temperature, has anyone else had this problem?
Hopefully the next BIOS release will cure the problem.
