MSI K8N NEO4-F
Hey,
I do appreciate the info on the BIOS. ( At least, they know about it ) I talked to one of the techs yesterday & Tues, but he didn't mention anything about the updated version. ( He did send me ver. 1.3 ) That sux 'cause i've packed it up and sent it back to them. The temperature sensor was not working. Reading a constant 26C idle or load.
Anyway i hope that i'll get the new mobo and update it to v1.41 and it'll scream.
Thanks again,
John
My CPU idles at 36°C and handles full load at 44°C. It's suprising that I have temps so low considering it's in a steel case with air cooling. I'll be pushing it to a 250Mhz FSB with stock memory speeds, 5/6 divider. That'll give me 2250Mhz, which is my goal. I'm afraid to try for a higher overclock with Valueselect memory.
After work I'll be hitting the driving range before heading home. So if no one has posted an update by then I'll still be attempting my overclock. It should be around 7PM PST depending on how long I'm at the range for.
keep this bumped up.
I also have the Hard Drive transfer hang problem.
I tried running it without the Nvidia drivers and with them. I even tried the latest Nforce4 drivers, still hanging.
I tried the 1.3 bios as well, again nothing. Does anyone else here know? Memtest runs fine, ran 20 hrs with no errors.
When I run Prime95 it was running for like 10 hrs but then it just hangs. You cant move the mouse, keyboard doesnt work. I dont know what is wrong.
I bought two of these, one for me and one for my aunt. My aunt works just fine, but mine wont stop hanging at random times, i think it happens only during high data transfers. Seems to be a driver problem. Sometimes I get the Blue Screen of Death as well.
BIOS didn't work for me. 219FSB still is fine, but a 220FSB will result in no POST. Hope someone else has some better luck...
Hey all,
So that BIOS update didn't work? Hmm, that sucks! I wonder if they even will get it fixed.
Your getting those temps from a Winchester 3000? OC'd right?
What's your VCore? Everyone says not to go over ~1.5.
Sorry about all of the questions, but you have a very similar system to mine.
Also, the hard drive thing... mine hasn't had any errors with the new drivers, but slowed down noticeably. I'll be doing a fresh load whn i get mine back from RMA.
Thanks again for everyones help.
John
Those temps are non-overclock temps on a Winchester 3000. My VCore is default currently. After all this I haven't even kept it at 219FSB for even a tiny overclock. I'll probably change it this weekend and keep it there until the FSB issue is fixed.
IMHO the more tech tickets submitted to MSI about the issue the better. So I definitely encourage everyone to at least submit the ticket, even if they don't want to use the BIOS they get sent. That way MSI will know that at least a few people want to overclock their systems and are limited by the board.
I just thought of something... is it just the nForce4 ( regular ) chipset that's having the problem OR is it the MSI Neo4-F board?
Is this happening on the nForce4 Ultras?
What about any other manufacuters that use the non ultra chipset?
Questions, man. They need answers. :evil:
Thanks,
John
1. From what I've read it's actually an nForce4 chipset problem.
2. The nForce4 Ultras seem to be fine according to the MSI Neo4 Platinum owners
3. A Google search turned up a Gigabyte board having the same issue with the non-ultra chipset.
Anyone know what a good step to take in getting a fix for the chipset would be? Maybe contacting NVidia somehow...
EDIT:
We tried to use software to lower down the multiplier, it works but after reboot, the system won't POST if we increase the FSB above 220MHz despite running the memory in async mode e.g cpu/mem = 200/166. We hope the production unit would improve in this aspect. *latest : according to Gigabyte, a new bios update will include new multiplier option and improve overclocking.
I still have hope that a BIOS update will fix the issue with the chipset. As I quoted from the webpage I found, Gigabyte will release a new BIOS update to improve overclocking. Hopefully AMD will as well.
Everyone should submit a help request to AMD about the 220Mhz FSB issue even if you don't have the board. 😀
I almost ordered the Neo4-F until I read this post. It's a good price too bad it's not stable (at least yet).
I guess I'll hold off on a new mobo until the ultra boards drop in price some more.
Originally posted by: cpush
fishbi, ever figure your problem out? any of you guys still having troubles?
Hi cpush
no, I never figured out what the problem was and gave up
on this computer.
I see someone else (AnimEva) seems to have the same
crashes I had when transfering files. I had checked my
hard-drives (2 x 160 Gb SATA), my memory (2x 512 Mb PC3200)
and all was fine. Basically, I tried just about everything for a week
and ...gave up.
Which is too bad...and I still need a new computer. I still want
an AMD 64 cpu but I'm not sure which motherboard I
should get now. Truth is, I just won't trust these NF4 chipsets now,
and I think I'll wait for the "dust to settle" with them...wrong or
right, but that was a bad experience and I can't afford this
(I am supposed to work *with* these machines, not *on* them...)
So yeah, I still want AMD64 + PCI-E , no SLI, let me know when
I can just buy something, plug it in and ..work. 🙂
Edit: I just read more posts and ...NF4 Ultra's are fine then?
Sure? Anyone working with them?
An Asus A8N-E could be alright, then, no?
Wow this is a scary thread, when you look at the reviews on newegg everybody seems please as punch with this board. I guess they deleted all the bad reviews.
Well, I am new, but I had the same problems and figured out a solution. It seems like the board doesn't liek the 40 pin 80 conductor IDE cables. Likethe one that ships with the motherboard ro an old one I had. I can't explain why, but with the 80 conductor cable the board would hang while booting Windows 2000. With the older 40 conductor cable it did not. With a different 80 conductor cable on the DVD-ROM and DVD Writer port, I could not get a good install of World of Warcraft. Replacing it with an old 40 conductor I had lying around got me a good install.
This may also be an intereaction between the motherboard, drives and the cable. Where some drives might work fine with the 80 conductor cable and others will not. The DVD-ROM and Writer problems seemed to be more intermittent than the hard drives.
Hello everyone, here is how to tell if you have the 219 bug - it really should be called the 219 - 229 cold boot hypertransport bug. Here is some excepts from my original post 2 1/2 weeks ago:
http://forum.msi.com.tw/index.php?topic=80211.0
In this illustration (from me in the thread), I let the bios ver 3.1 autoset the memory timings. On each cold boot post, the bios autoset the vdimm at 2.70v and the memory timings were autoset at 2.5,3,3,8 at 1T (1T manually set).
1. fsb 218x9, htt 218x5, ok
2. fsb 219x9, htt 219x5, ok
3. fsb 220x9, htt 220x5, no cold boot post
4. fsb 220x9, htt 220x4, no cold boot post - this is the 219 bug...at higher fsb, it really starts to affect performance
5. fsb 220x9, htt 220x3, ok
6. fsb 221x9, htt 221x3, ok
7. fsb 222x9, htt 222x3, ok - highest stability level of my valueram at 1:1, prime95 and memtest stable 8 hours plus each
However, if I manually lower vdimm to 2.55v and manually raise the n4 chipset voltage to 1.55v, my rig cold boot posts 4 out of 5 times at 222x9 and 222x4...
And some more from me...
I just dont accept the arguements that this cold boot 219 - 229 hypertransport problem doesnt affect performance...it does...
My test scenario is setting the ref clock(fsb) to 250x9, ht frequency multiplier to 250x1 and memclock to 166. At this setting, I can cold boot my rig no problem. I did overclock my MSI 6600gt to 11% (555/1110) because if you use DOT, the average person can overclock to this level (using coolbits, I can get to 580/1160). Here are my test scores - I test twice just to be sure and cold boot post each time:
Test 1 - 250x9, 250x1, 166 - 3Dmark05=3748, PCmark04=4388
Test 2 - 250x9, 250x1, 166 - 3Dmark05=3744, PCmark04=4394
The change I made using clockgen is to initially set fsb to 200x9, ht freq mult to 200x4 and memclock to 166. After I cold boot post, I use clockgen to increase fsb to 250x9 and by default, the ht freq multiplier is at 250x4. Here are my test scores using clockgen:
Test 3 - 250x9, 250x4, 166 - 3Dmark05=3983, PCmark04=4531
Test 4 - 250x9, 250x4, 166 - 3Dmark05=3986, PCmark04=4529
As you can see in every test case, I take a performance HIT when I have to boot at ht freq multiplier at x1 versus using clockgen after you boot to windows xp (which freq mult is set at x4 at 250).
I just cant get over the fact that we have to accept lesser performance since I can get to 250x4 thru clockgen but not through the bios thru a cold boot. IMO this is a bios problem-period!!!!!!!!!! And I hope this is a bios problem because if its a problem with the motherboard, then were all SOL....
And finally what Wesley Fink and Kristopher Kubicki from Anandtech did when they confronted MSI at Computex this last week:
Anandtech has now formally announced the following on its website:
Unfortunately, we have recently discovered some performance issues when using the board with 90nm processors, so until MSI can release a BIOS update that addresses the issue, we would avoid the board.
Update: After this Guide was initially written, it came to light that the MSI boards are having problems with 90nm parts. The MSI Neo4 SLI was our original high-end pick, but we changed that out after the new information. Sorry for the confusion!
Will MSI care to notice this and get this bios fixed soon?
http://www.anandtech.com/guides/showdoc.aspx?i=2426&p=2
However, The Problem Gets Worse! Well, the thread was locked on the MSI forum boards and a few users have been banned regarding the 219 cold boot hypertransport bug - actually 2 threads on the issue. The mods refuse to acknowledge the problem!
http://forum.msi.com.tw/index.php?topic=80974.0
http://forum.msi.com.tw/index.php?topic=80211.240
A new thread was started a week ago on Rebelshaven for those interested in this 219 bug and any updates to the problem - THANK GOD FOR ANANDTECH FOR HELPING TO GET TO THE BOTTOM OF THIS PROBLEM WITH MSI!!!!!!!!!:
http://www.rhcf.com/sisubb/ultimate...c/21/242/3.html
I was kinda looking into grabbing this mobo myself also for a cheap socket939 solition but after reading all of this it looks like MSI screwed up again. 🙁
Hi
I bought this board but dont overclock but it seems stable.
The only issue i have seen and not sure if it is the new sata controller or something is that the only drive i have onthe system which is a 36 gig raptor seems to be showing up as a remoavble drive.
Anyone else have their sata drives showing up like this or seen it on other motherboards?
it is a very stable board if you don't overclock from my experience.
i am not using sata, YET, so i am unsure of that issue.
hopefully someone will know and let us know b/c i am looking into a sata in the very near future.
I was looking at this board as well....this thread is not too convincing......does any one have a good A64 Mobo that is inexpensive? I need to keep it on the cheaper side, but want quality, but not SLI
I'm about to buy a board and think I am going to go with the ECS KN1 Extreme, about the same price but it uses the Ultra chipset.
I'll post once it's received and installed.
Pete
I just got one of these boards but I have NO VIDEO on my MSI + ATI AIW ....I need help!
I just order the following parts for a new build:
MSI K8N Neo4-F
ATI AIW X600 Pro 256 PCI-E
Liteone DVD
WD 160 HD
1 GIG of Ram
I got everything together and the computer comes on. but I have no video signal to my monitor. I hooked up a pc speaker and according to the beeps it had a problem with the video card initializing. Should I assume the vid card is bad and exchange it or could the mother board be bad also?
I have the new version 1.5 BIOS release that is supposed to fix the overclocking issue.
Alas, the board still stops out around 220MHz HTT.
I'm really starting to think that I should dump it for a DFI nForce4-Ultra board.
