MSI K8N Diamond: No more than 230htt?
sYbb
13
I have tried the HTT-Multi 4x know as you said myocardia, but the system didn't boot either ...
I'm seriously thinking about selling the MSI ...
Lonyo
21,938
Try a different BIOS.
My K8N SLI Platinum had no problem with hitting 260MHz FSB. Then I updated the BIOS to give me more voltage options, and I hit a limit at 240MHz. Since the old BIOS had worked fine at higher frequencies with all the same voltages, I suggest changing your BIOS, possibly to an older version, or a newer one if available, and playing around like that.
avi85
988
Originally posted by: avi85
Originally posted by: myocardia
And lastly, MSI motherboards absolutely hate USB mice/motherboards. Were you aware of that? You'll probably want to get yourself a PS/2 adapter, if you have either.
Can you tell me more about this, or provide a link?
tvdang7
2,242
too lay to read all the other posts but its a known problem with the k8n's with winchester's i know i used to have that combo. i got up to 230ish in bios from then i had to use clockgen to take it the rest of the way. good luck.
sYbb
13
can you recommend me any other motherboard - doesn't have to be an an sli-board - with good overclocking features?
