Hi everyone!
I am a (sad) owner of an Abit KT7A-RAID motherboard, and I've also had problems like yours. (No Boot on Cold Boot)
The Reset button-solution worked for me too, but after reading some FAQ:s and doing some investigations on other forums, I came up with a workable solution (I think...).
I started by adjusting the I/O voltage in BIOS (SoftMenuIII) to 3.4 volts, and then i raised the AGP Driving Strength to FF (hexadecimal).
I still don't really know if this solves the problem forever, but since I did these adjustments, I've had no problems with cold-boots. OK, I've only cold-booted twice since then, but it's worth a try isn't it?
BUT... There is still one problem left, and that is that when Windows ME starts up, (on a "successful" cold-boot) it always finds a new "PCI VGA compatible display adapter".
The screen is grey instead of "Win ME-blue" and screen resolution is set to 640*480, 256 color...
Now I should tell you all that I HAVE installed the proper drivers (Version 5.33) for my video device (Asus V7700 Geforce2 GTS DDR TV-Out) and the last time i closed down Windows, everything was fine and dandy...
After a while it says it's found a "Standard PCI-video device (VGA)" and asks me to restart my system to complete the installation.
After this I have to restart my system TWICE again to get my former screen resolution back (1152*864, High Color).
THIS KEEPS BUGGING ME!! Does anyone have a solution for this? It seems the system (Win ME) detects new hardware everytime I cold-boot my system... 🙁
I would appreciate if someone came up with a possible solution to this problem. Thanx.
