Question MSI G241 MONITOR HELP
hardcore_gamer29
any one using this monitor ? what options should i enable or disable in monitor OSD my game is not smooth it is tearing and movies are also not smooth they are stuttery i will have to return it if any one using it please suggest some settings
thanks
Visualize victory with the MSI Optix G241 eSports gaming monitor and the picture quality 4.8/5, brightness 4.5/5, and many other specialties that make this monitor is good. Equipped with a 1920x1080, 144hz Refresh rate, 1ms response time the Optix G241 can match the display's refresh rate with your GPU for ultra-smooth gameplay. You should have to check the software, it may be there is a software problem.
there is ips glow on all 4 corners should i return it?
