I've just gone through the same thing with finding the right linux distro for me. I tried Mandrake 9.1, RedHat 9, Debian woody, Knoppix 3.2, and SuSE 8.2. I like SuSE the best and have found it the best and very easy to use for a former Windows user. YaST2 is very easy and I actually sort of prefer the FTP install now, after having done it. What I did is download the entire "8.2" folder to my non OS partition (NTFS) with Windows, then burned the boot disc, booted to it, and installed the NTFS module. The installation was fast and I didn't have to worry about having a bad burn or anything. Also if I want to add packages now all I do is open YaST2 and select them, then it just installs them. This isnt for the impatient or those without about 6GB of hard drive space to burn, but I found it great and once you get it set up how you like, you can always delete the install directory. To see if you like SuSE you can always download the live-demo disc. Good luck.
--Ryan
--Ryan
