Throckmorton
I use a fingertip grip and since 1995 I preferred the speed slider in Windows set to max. Then I got a G9 and started gaming at 3200dpi with the slider centered. For some games/weapons I lowered it to 2400dpi.
I now have a Roccat Kone Pure which I set to 3200dpi at the highest setting, because that's what I'm used to. Well for the first time I've tried turning off "enhance pointer precision" along with the registry edit that turns off all acceleration. Now 3200 dpi isn't enough! I upped it to 4800dpi.
I use a fingertip grip, and at that DPI I can easily move the pointer across the screen. It's a bit too high for FPS games and 3200dpi seems to be more accurate for me.
A lot of gamers seem to prefer 800dpi, and some even turn down the speed in games to further reduce speed. How can they move the mouse that much without fatiguing their wrists? Why can't they aim at a higher DPI? I understand you naturally move the mouse more with a palm grip but come on. Why would you choose to flail about unless you lack the dexterity for higher sensitivity?
