Probably. Intel has made up a fair bit of ground over the last few years, but that was while AMD's parts were hamstrung by their weak CPU cores. Zen APUs should put a fair bit of distance ahead of their Intel rivals, albeit with the latter now being just about viable (though certainly not optimal) for casual gaming.
I agree, AMD should be easily ahead for casual gaming vs Intel iGPU.
As was show is that sweet spot for Ryzen performance/watt is at lower clocks, around 2-3 ghz. There it's actually better than intel! (well after all GF 14nm is a low power process). I think the bigger issue here could actually be Vega iGPU taking Vega FE as indication.
Is there anything definitive on this. So much of the testing is different core/thread counts, different clock speeds that it really blurs the picture, so it is hard to get a handle on real perf/watt.
But if you compare actual work, of identical core/thread counts, Intel does
Better on perf/watt (with the possible of exception of the their HEDT quad memory channel chips, which seem to have issues).
Here is two benchmarks that include power usage (including one of AMDs favorite benches Cinebench). Compare the Ryzen 1500X to the 7700K. Both 4C/8T, with Intel running higher clocks, so no surprise it is faster:
https://www.techspot.com/review/1379-and-ryzen-5-1600x-1500x/page3.html
CineBench:
7700K 941 points 137 watts
1500X 797 points 154 watts
Excel:
7700K 3.26 seconds 133 watts
1500X 4.06 seconds 148 watts
But Intel also using less power while running at higher clocks and delivering more performance,
in both Cinebench and Excel benchmarks.
Intel performs better and uses less power. Will lower clock speed reverse that? I'd like to see a demonstration.
