Hi ALL,
I am having problems with my computer, and I have pretty much isolated it (I think), to the moterboard. I have an ABIT BE6-II MotherBoard. I have an Intel Celeron 1 GHz FCPGA1, 512MB PC133 RAM, 60GB 7200RPM HD, Ricoh 7200A CDR/RW, 50x CD-ROM. I am running Windows XP Professional. Well, the other day, I was running Windows XP, and I had to run out for a few things, and then when I came back, my monitor was in suspend mode, so I tried to move my mouse to bring it back, but got nothing. And normally, on my monitor, when it is in suspend mode, it flashes from orange to green, but this time it was straight orange, which most likely means no signal from the video card. So I decided to reset my computer. When I pressed the reset button, nothing happened. So then I decided to do a power off. I held down the power button, and again nothing happened. So I decided I had to cut the power manually, so I switched off my surge protector. But when I plugged it back in, and turned the power on, nothing happened, the computer power turned on, but the BIOS did not post, the hard drive did not spin up, and nothing was on my screen, and there was NO BEEPS of any kind. And again I could not shut off the computer using the power switch, only by turning off the surge protector.
I then opened the case to see if I could find the problem. I first removed the ATX power connector to my motherboard and let it sit for a while, then after I plugged it back in, nothing. I then removed all my PCI/ISA cards, and replaced my video card with an older back-up I had. Turned the computer on, and nothing again. Next I tried the memory, again nothing. Then I tried the CPU, and again nothing. Then I got to my IDE ports. I decided to remove all the IDE devices, except for my HD, and then when I turned it on, again nothing happened with the computer, BUT the CD-ROMs (which were still on the power supply), turned on and I could eject, etc., but the HD would still not spin up. So then I decided to pull my HD out of the IDE port too. When I turned it on, my HD spined up, and I could tell it was ready to go. But whenever I plugged any of the IDE devices back into their ports on the mother board, same problem, they would not "activate". So I guess I would be correct in assuming that something has gone wrong with my motherboard? Does this mean it is dead, or is there something I can do to try and re-initialize it. I did already try and reset the BIOS using the jumper on the motherboard, but nothing happened. My motherboard is no longer under warranty, and I want to know if there is anything I can try before I have to go buy a new one. Now there was one very wierd thing. Right after the first time this happened, I turned off my computer, removed the ATX power to the motherboard, and waited. Then I plugged it back in and turned on my computer. Again nothing happened, but this time I left it running. After about 10-15 mins, all of a sudden, the monitor came on, the IDE devices started up, and the BIOS posted. All my BIOS settings were normal, and I booted into WinXP. I was able to use my computer for about 2 hours, and then again, the screen went black, and I could not turn off the power with the switch. Since then, I tried to do the same thing again, but this time it would not come on. I even left the computer running overnight, in hopes that it would activate, but it never did. Any help would be appreciated. Thanks.
SuperG03
SuperG03
