Zap
Originally posted by: Denithor
Because both Crysis & COD4 are available for the XBOX360, which will only cost you $200 these days. And it's going to cost lots more than that to build a PC truly capable of pushing those games as well as they will run on the X360.
Does anyone know what settings correspond to options in the PC version? I know the XBox 360 is limited to 1080p resolutions (1920x1080). Does the console versions run any AA or any other settings that can be cranked in PC version?
Originally posted by: kpburd
That is an excellent choice except for the price. That makes me believe I'm not going to get what I want for $100.
You want a micro ATX motherboard under $100 that can take a 9600 GT graphics card, DDR2 RAM of various speeds and can handle a Core 2 Duo E7400, right? Newegg lists over 50 choices. If you don't need more than 4GB total RAM or more than two RAM slots, I'd go with the Gigabyte GA-EG31M-S2 board.
Originally posted by: TidusZ
I'd personally rather use a atx mobo and no case (or cardboard/makeshift case) than use a matx motherboard.
"It is bigger, therefore it is better" only works for monitors, fans and monster trucks.
I'd venture to guess that for most people if you surreptitiously replaced their ATX motherboard with a suitable micro ATX motherboard without telling them (assuming Windows doesn't die from the swap), they would not know unless they peeked inside their case or went out of their way to examine monitoring software.
