most cost efficient way to get flat car tires replaced? (Update 5/22)
May 13, 2009
12,333
612
Used tires are fine. A visual inspection before installation and you're good. A 13 year old beater is a perfect candidate for used tires. On our new daily driver's we use new tires. On my 24 year old mustang or 10 year old truck I'd definitely go used.
kitatech
484
On the topic of used tires...
The one thing to consider with used tires is you often don't get to choose what you get - you pay your $30 or so and they go to a big stack and pull off the tire(s). So you might get the almost new tires I described in the previous paragraph or you might get something that will last only a few months or a year.
In the case I mentioned on p. 1 about "pull-offs", the guy at the used tire shop took a photo with his phone of my new front tire and then took me back to the rack and found a match! It wasn't the same brand but was a match, made in the same factory a week after my front tires (it pays to be able to read tire manufacturing codes)
....serendipity and just good luck, of course...
