Originally posted by: TheVrolok
Originally posted by: CVSiN
CT mod sucks doesnt have half the features i use regularly...
Cosmos is not buggy at all.... what part are you useing thats buggy?
map mod... wep mod... Questshare/Questminion DPS meter Time calc.. rogue helper... compass mod...
ive been using it for almost 1 year with 0 problems....
its not "bloated" its just a couple .XML files doesnt load or affect anything at all
it automatically clears folders and downloads the latest build every time i log in.. (and if you use Alpha build it loads the newest version every day)
oh well CTmod is ok if all you need are extra toolbars.. i prefer a whole toolbox worth of customability and tools.
Cosmos caused some serious issues with numerous error messages for a few days after the most recent patch, that's the second time I gave Cosmos a shot and still received error dialogues and found it to be bloated. CT ALSO has a map mod/toolbars/combat mod/dps meter. I think the questminion, etc. in Cosmos are really just bloat. Is it REALLY that hard to ask someone what quest they have? It's nothing but eye candy to me. Like a clock? Is something wrong with the mouseover clock that's built into the WoW UI? That defines bloat in my opinion (redundant superfluous functionality).
And to respond to NeoV about Macro's.. they are invaluable. I use at least 8 constantly on my Pally, just check out the WoW UI forum, there's a list of really common (and handy) ones. From there you'll learn to make whatever you find you begin to need.
Um same thing happens to CT mod after every patch... you have to to redownload the latest build after any patch..
Cosmos makes it easy by having a button that does it automatically... and your errors go away.. thats not cosmos's fault that you cant figure it out...
how is something "BLOAT" as you put it when there is no overhead? its not anything that loads into memory or executes.. its a simple .XML file same as CTmod... with more things in the tool box.. and no CT mod does not do the things that cosmos can...
its a halfassed attempt..
Quest minion is not eyecandy... its a list on your main window that shows what quest you are on and how many or what items you still need to complete it...
Weapon Hot switch buttons on main screen.. enagbles me as a rogue to never have to open my bags or my paperdoll to poison my weps or switch weps..
Clock.. uses the same clock as WoW does but enables locg trackers for level... level time.. time to next level.. distance travled... time played this session... and alot of other stuff i cant even remember at work.. but i use it alot...
totem stomper for shamans = very cool...
Gotmoos Buff mod = uber...
rogue helper= much better combo point/energyn meter than what WoW gives...
5 extra quick bars... with artwork removal... ability to make empty buttons disappear etc..
map features WAY WAY superior to CT mods...
Tackle Box= Fishing helper pretty cool if you fish...
I dont understand why some of you retards think that Cosmos = Bloat... becasue you only use what you need... rest doesnt affect you.. it doesnt use any more memory than the regular UI or CT mod...
yet half the people that complain about it arnt smart enough to figure it out...
oh well keep using what you like ....we will keep using what is best =P
