Monster Cables for my Klipsch Promedia 2.1's
SofaKing
Banned
Nov 29, 2004
5,315
So I was surfing the monster cable website, which one would I get for my PC Klipsch 2.1 Speakers?
SofaKing
Banned
Nov 29, 2004
5,315
Thanks a lot. My cables are kinda screwed up now, so everything sounds fuzzy and when I turn up the volume it's all screwed up, do you think Klipsch will send me cables for free?
OdiN
Banned
Mar 1, 2000
16,430
You can always ask, and yeah the link I provided is Klipsch's monster cable set for your speakers.
SofaKing
Banned
Nov 29, 2004
5,315
Originally posted by: ribbon13
http://www.klipsch.com/product/product.aspx?cid=103
muhahaha. Monster cable too..
ok. I won't bag on you for buying overpriced speakers made out of plastic...
looking at the back of the sub...
http://www.laaudiofile.com/images/pm21a.jpg
you just need plain 16ga zip cord. nothing fancy will make it sound any better.
You can get 50' of that for $17
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-142
Hey, I got these for $80 shipped on Hardforums, not a bad deal at all for me :)
I think I'll just get a cheap cable like you mentioned.
imported_itr
900
ribbon13 is correct. you do not need any expensive speaker cables for speakers that aren't very high end.
SofaKing
Banned
Nov 29, 2004
5,315
These speakers aren't considered high-end? :confused:
Well, I guess, since it's only a 2.1 setup.
MrChad
13,507
The connection on the subwoofer is just a standard speaker wire, however the connection on the satellites is a miniport. Hence the connectors on the monster cable. The link you provided is incomplete; you would still need miniport connectors and solder.
OdiN
Banned
Mar 1, 2000
16,430
To audiophiles they aren't high end until each speaker costs $1000 per cubic inch....regardless if they sound like crap or not. Klipsch speakers sound great.
SofaKing
Banned
Nov 29, 2004
5,315
ehh, I might just get a set of replacement cables from klipsch if they decide to give me some.. or I'll buy those monster cables from Klipsch's site, but they're a bit pricey.
ribbon13
9,343
Well, why not look at the back of the speaker and tell us what kind of connectors you need? lol
I could see 4 pins, and 1 mini phono plug..
SofaKing
Banned
Nov 29, 2004
5,315
Eh, I'd rather not have to do any soldering.. I'll try my best to get replacement cables from Klipsch!
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
As much as I dislike monstercable, $30 isn't too much to spend on this if you need specialized cable ends and don't want to solder anything.
Googer
12,576
7
BOSE Defies that description, they sound great too.
