Monitor viewing distance
toslat
216
Have heard people say that a monitor cannot be too big, but I disagree, since you will likely get a neck strain if you sit too close.
Looking for a formula (or table) that gives the max/min distance for viewing monitors of different sizes at different resolutions.
Denithor
6,298
23
Depends more on whether you sit (in your normal position) level with the screen or not. When I lean back in my chair at home my monitor is just slightly raised which works perfectly for me. 27" looks great from 3' away, very immersive for gaming & movies.
toslat
216
So how close/far would you recommend one sit from a 32 inch screen for bowsing and documents?
Denithor
6,298
23
720p or 1080p?
720p you're going to have to be at least 6ft away or more just to tolerate the large font. 1080p will look much better, you could probably use it just like I use my 27" Dell (2-4ft depending on whether I'm reclining or not).
NitroTurtle
123
I sit about 3 feet away from my 37" Westy. My eyes aren't too good, so it makes for easier reading. :)
