monitor trouble 2407wfp
spyral
Hey guys I just hooked up a 2407wfp to my PC. I currently have a 1900XT
Im seeing wierd disturbance on the screen at the monitors native resolution. Everything is fine if the desktop is a plain color but if i put an image as a wallpaper I see wierd flickering lines on the screen. Also, regardless of background, I see a wierd disturbance on the startbar.
Ive installed the card drivers etc but nothing has helped so far. Any idea what I should do?
Desktops
Legacy/Current AGP Video Card Support
*Legacy AGP Video Card Support - Requires video driver update from support.dell.com
Graphics Card 2005FPW 2405FPW
ATI RadeonTM X800 XT 256MB DDR-SDRAM
*Yes *Yes
ATI Radeon X800 SE 128MB DDR-SDRAM
*Yes *Yes
ATI 256MB Radeon 9800XT
*Yes *Yes
ATI 128MB Radeon 9800Pro
*Yes *Yes
ATI ALL-IN-WONDERTM 9000 64 MB DDR-SDRAM
No *Yes
ATI Radeon X850 XT Platinum Edition 256MB DDR-SDRAM
**Yes **Yes
NVIDIA GeForce 6800 GTO 256MB
**Yes **Yes
NVIDIA GeForce 6800 256MB
**Yes **Yes
ATI Radeon X300 128MB PCI Express x16
**Yes **Yes
ATI Radeon X300 SE 128MB DDR-SDRAM
**Yes **Yes
ATI Radeon X300 SE 64MB DDR-SDRAM
**Yes **Yes
Intel® GMA 900
**Yes **Yes
I dont see a video card you have on the list.
There are no Dell drivers for that monitor yet. I know there is a Windows Update for it, though I have no idea what it 'fixes', if anything.
I have the same mintor and card, but I never had any problems like that. Is your monitor revision A02?
Also, are you using DVI or VGA? Maybe switch and see if it helps. I remember reading somewhere about this helping a guy's issue (can't remember exatly what it was about, sorry).
Not that it is a good long-term solution, but at least you could see if it helps.
Hey there,
I got a 2407WFP just last week. Can't say I notice anything like what you describe and I've used the monitor with both an ATI X800 AGP and a BFG 7900GT. I was using the monitor via DVI both times.
There is in fact a Dell driver, and it can be found here:
2407WFP Driver
Hope this helps!
mattrickulater
Originally posted by: mattrickulater
Hey there,
2407WFP Driver
Hope this helps!
mattrickulater
Huh, wow. I had only ever seen a 3007 driver...thanks for the link!
Figured it out but it dosnt end well for me =/
One of the DVI ports on my X1900 seems to be messed up. Still works with a converter tho.
Thanks for all the help guys.
Oh and to the first reply, the list u have there is for the 2405 and not he 2407. Dell hadnt updated their site last I checked and it seems like they still havnt. Thanks for the help tho.
