Monitor - text not as sharp
watek
937
Is it normal for a shadow mask crt? Text looks all grainy and fainted. Comparing it to my flatscreen crt, there's a huge difference. Something wrong with this monitor?
Jan 31, 2002
40,819
Are all of the following equal:
Resolution, color depths, refresh rates, video card, connector quality, cable length
If not, then you're not doing an apples-to-apples. ;)
- M4H
Zepper
18,998
Are you driving it too hard? May need a degaussing or a bit of tweaking on the focus.
.bh.
tynopik
5,245
500
1. what is the max spec refresh rate for your current resolution
2. what is the refresh rate are you running at
boborich
154
It depands. You have to tell the models of your display.
