Monitor Suddenly Blurry
vshah
19,003
24
I was sitting around reading emails, when my monitor does the little refresh thing where it goes blank for a moment, as it does if you are changing res or refresh rates...and it comes back with everything blurry. Restarting hasn't done anything, nor has leaving the comp off for a few minutes. I'm pretty sure its something to do with the monitor and not the vc...any ideas?
Thanks
-Vivan
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
Thanks
-Vivan
Leave it off for a few hrs. Then try again, if it is still like that it can be the monitor or the graphics card.
Have you got a spare graphics card to hand? What about a laptop or a friends latop with vga out? Try that. If the monitor still has that problem with different graphics cards or laptops the monitor has gone to the monitor place in the sky. No it is not Dell :eek:
Koing
Ionizer86
5,292
What happens when you change the refresh?
Next test would be to plug the monitor on another computer (if you can).
vshah
19,003
24
Update:
Odd thing...i turned it off for a few minutes and the problem was still there...tried the monitor on my laptop, no problem, tried a new graphics card, no problem ...so i figured probably the graphics card...just for luck though i put the 9700 back in and turned it on...works fine now
back from the dead it seems...i will pray tonight :D
thanks
-vivan
Koing
Oct 11, 2000
16,843
Update:
thanks
-vivan
lol glad it works :D
Maybe it wasn't seated in properly? Probably that or something to do with a connection or possibly dust particles......
Koing
