Question Monitor size and resolution?
BoomerD
66,595
14,996
Let me just start a new thread rather than crapping in other people's threads.
I'm seriously looking at replacing my 12 year old Dell 24" 1920 x 1080 TN panel monitor. it still works...but....damnit, I WANT a better monitor.
I'm somewhat torn between 27" and 32"...when I sit at my desk, my eyes are about 28-30" from the screen. a decent arm's length.
Physically, I can fit a good quality 32" monitor on the desk...depending on the stand, it MIGHT end up with a bit shorter eye-screen distance...or not.
QHD or 4K? I have an ASUS 2070-8Gb video card and intel I7-9700K CPU. It SHOULD run 2560 x 1440 with little to no problem...but MIGHT get a bit hotter when gaming.
I suspect a 4K monitor would tax the card's capability and I'd really have to turn down game quality in order to maintain a decent frame rate. I'm sure it would be fine for my other uses...just not for gaming.
Unfortunately, living way out past the outskirts of BFE, (about 75 miles to the closest Best Buy) I really don't have any place where I can go and physically see the different monitors and their resolutions.
(Walmart and a small Staples store are the only local places that have ANY monitors...and they're mostly crap...or not meant for gaming.)
Use for the monitor will be primarily FPS gaming, intarweb surfing...occasional Excel work, (nothing serious, just household crap) and occasional word processing.
I'll PROBABLY get another Dell...unless someone can convince me otherwise.
Currently, Dell has the following that I'm looking at:
32" S3222GDM for $299 with free shipping. (QHD, VA panel, up to165 hz refresh rate.
27" S2721DGF for $329 with free shipping (QHD, IPS panel, up to 165hz refresh rate)
both have the Dell 3 year replacement warranty
A couple of semi-local (Olympia-Tacoma) people have the Dell S3220DGF (QHD, VA panel, up to 165 hz refresh rate) for $300 or less...but being used, no warranty.
RTINGS.com rates is slightly better than the S3222GDM that replaced it)
I'm trying to stay around $300 or less if possible.
Any info/opinions would be appreciated.
biostud
20,108
7,212
Nah, I've looked at a couple of UW monitors. They just look odd to me.
But once you've worked and gamed on one, you never go back. Just saying ;)
The ability to use it split screen for productivity or a large excel sheet. And the extra width really gives something when gaming.
BoomerD
66,595
14,996
I get it...but since I share a desk, I really don't have the room. I've looked at them...Dell has a 34" that's about $500...but it's just too wide.
mnewsham
14,539
428
I personally still don't really "get" UW monitors (mostly).
You can just buy a larger 4k panel and make a custom resolution for UW aspect ratio and just have some black bars on the screen.
Sure it's not as clean looking, but not all games support UW aspect ratios, and a larger 4k panel for 4k movies just seems more sensible than an UW at 3440x1440 that can't natively display 4k content and ends up costing nearly as much as a larger 4k panel of nearly identical pixel density would cost.
But back to the topic of the thread, boomer you might just need to bite the bullet on something from amazon you can do an easy return on, or spend a chunk of a day driving out to see what monitors are available within driving distance you can look at in-person.
biostud
20,108
7,212
Refresh rate is seldom as good on 4k as on 34" UW, and you would need a 43" 4k to get something similar to 34" width and preferably something with a curve. Don't know how many 43" screens has that. :)
BoomerD
66,595
14,996
mew, it's uncommon for me to watch anything more than one episode of something on prime or netflix on the monitor. I have a 65" 4K tv as the main one, and a 55" as the "extra" in one of our spare rooms. (and a Panasonic 65" plasma in its box in the garage...still not sure what I'm gonna do with that.)
I found a 1 year old Dell S3220DGF on Facebook for $250...and IF Dell will allow me to transfer ownership, (not always guaranteed) it would have 2 years of warranty, but my track record with buying used electronics isn't stellar...as my wife reminds me :oops: and the newer version, Dell S3222DGM (better in some ways, worse in others) is on sale for $299...If I could get the used one for $200, I might be willing to fight for it, but the sellers are sticking to their price...so I'm probably going to get the newer new version.
I really like the Gigabyte M32Q, but Gigabyte's customer service has never been great...and the "exploding PSU" thing...makes me leery.
BoomerD
66,595
14,996
Received the new Dell S3222DGM today. WOW! this thing is HUGE! (coming from a 24" TN panel) Colors are vibrant and the picture is so clean and clear. I've only done a bit of gaming to test it out...temps have gone up slightly, but not much. (less than 10 degrees so far) Can't speak to frame rates...haven't done enough to really notice any difference.
I'll post a pic or two later.
Overall, I'm quite impressed.
mnewsham
14,539
428
You'll need to go into the Nvidia control panel and probably need to switch it to 144/165hz
Most systems will default a new monitor to 60hz.
