I have a Samsung 955df monitor. It is supposed to be able to do a resolution of 1280x1024 @ 80Hz. Windows XP will only allow for 75Hz or 85Hz (which it cant do). Is there a way to manually set the refresh rate to 80 Hz in windows?
it's 79 not 80 that is a difference, windows will not let you set it to 80, to get that 79 you should take max vertical freq. and multiply it by some fraction that I forgot and resolution - that will give you the exact refresh rate for all resoultions.
yeah, it recommends 1280x1024 at 75Hz, but i would really like to get 80 Hz out of it. It can do 1280x960 at 85Hz, so i would assume 1280x1024 at 80 Hz would work fine.
it looks like powerstrip will fix the problem. thanks
