Looking for a 23" or 24" monitor with hdmi, dvi and vga connections, not sure if i want to get a tn panel or ips panel. i don't do any gaming if that matters.
Don't want speakers or webcam built into it.
Suggestions ?
Knowing your budget and what your intended use is will help us make a recommendation. :biggrin:
Budget of $150. Use for everything.
It's a 1080 TN panel. ^_^
I'd scrape up a few more bucks and spring for a 1200 IPS, if I were you.
Such as ?
It's your money, spend it however you like.Dells are reasonably priced, here are a couple options
http://www.newegg.com/Product/Produc...82E16824260055
http://www.newegg.com/Product/Produc...scrollFullInfo
http://www.newegg.com/Product/Produc...82E16824260148
