Monitor recommendation?
Kev
16,367
4
It seems like they don't make good monitors anymore. I have bought and returned 5 monitors of varying makes and models over the past few months and I can't seem to find one that doesn't suffer from annoying backlight bleed or IPS glow or dead pixels. It's incredibly frustrating.
Will Robinson
1,408
Hmm,tried the Dell H-IPS Ultrasharp 2410?
16:10 aspect ratio with 12bit internal processing....it's a beauty! :awe:
BrightCandle
4,762
My 2410 has a small amount of backlight bleed and the matte coating is quite noticeable as well. I do however have zero dead pixels.
No idea what IPS glow even is.
moonbogg
10,737
3,455
I take it you are only speaking about IPS monitors. I assume then that any TN would make you vomit instantly?
MrK6
4,458
4
It's tough to recommend something without knowing what you've specifically tried. The higher quality Dell IPS monitors are usually perfect, and if not, they have a zero-questions-asked advanced replacement policy on new monitors. The other thing would be to go to a store and actually check out the monitor you're buying before you pick it up.
moonbogg
10,737
3,455
Well, I have an Asus VG278 and have been very pleased with it. I have wondered what it would be like to have a high quality 1440p IPS monitor, but in the end I know I wouldn't be able to stand the lag of IPS and I don't want to go back to 60hz.
What is important to you? With monitors, there are big time trade offs you have to make.
BrightCandle
4,762
Well I had a look at IPS glow and yes I have some as well. My 2410 isn't as severe as a lot of the images on Google but its definitely a noticeable effect on a darkened monitor.
The other problem I have with the 2410 is actually the brightness. 0 brightness is still too bright and I end up messing around in software to get it down to something usable and then the calibration is far from perfect. But that seems to be just me, I am not keen on overly bright images.
Tweak155
11,449
264
I didn't like my U2410. I sold it after a while. The coating on the monitor is just ridiculous. Unfortunately I would not recommend it.
