Monitor Reccomendation 19" or greater
finners
45
Looking for a monitor for CAD/CAE work primarily so I guess a nice high res may be in order.
Obviously I would like the text to be very clear.
I wouldn't call myself an extreme gamer. I do like MS Flight Sim however.
Also would like to watch movies on it.
Important that the LCD will be a good all rounder.
Thanks
finners
45
Sorry I should have stated my budget which is $500. The 2405FPW is a bit too pricey
finners
45
That seems ok apart from the fact that its widescreen. Not sure about buying a widescreen!
IeraseU
778
I like widescreen for CAD work, you can fit more toolbars on the side of the work area while still having a big enough view of what you're doing....might take some getting used to, if you're used to 4:3 or 5:4, but i'm confident you'll adjust quickly.
tuteja1986
3,676
