Originally posted by: 0x0BADF00D
xt,
Would this profile import properly into OS X? Mine imported without errors, although I can't really tell if that's how it's supposed to look. It looks darker, and more saturated. Definitely darker than Apple's standard 1.8 gamma. Is it the ideal for text as well?
Thanks in advance.
Originally posted by: mallow005
How do I set xcalib to apply the ICM profile automatically on startup? Will it automatically use the last ICM profile? Should I take out Adobe Gamma from my startup folder?
Originally posted by: xtknight
I will start off. Please put them in a format similar to below for easy reading.
LG L226WT - L* 200 cd/m2 @ 6500K (daylight)
by xtknight
Results
ICM Profile
Settings:
Brightness: 72
Contrast: 65
Gamma: 0
f-Engine: Normal
Color: sRGB
Sharpness: 5
Originally posted by: pdawg1717
Btw, what are peoples' opinions on this: Is it more important to have minimal color grayscale banding or minimal backlight bleed/better blacks?
Originally posted by: bryanvlo
Would be great if someone put up a 2407-HC profile.![]()
Originally posted by: Shimmishim
xtknight very nice thread. this is exactly what i was looking for.
do you have a guide as to how to load the icc profile for vista? i can't seem to load profiles via vista. i might be missing something obvious
Originally posted by: Howard
Don't you run into consistency problems when you use profiles for other monitors?
Originally posted by: dedejean
hi. i just bought a LG226wtq-WF v1.14, i cant seem to make a good profile. Does anyone of u have a good one?
Originally posted by: DLeRium
Anyone got settings for the Viewsonic VP191b? This is the older brother of the VP930b...
Hi, I also recently bought this particular monitor, and I would also like to request a good profile for it. I tried the one for the L226WT, but it just washed everything out and didn't look right.
Also, I have the 3 panel types in my service menu (CMO22W.4, LPL22W.4, and LPL22W.G.4), and was wondering which one I should be using.
Thanks!
Originally posted by: FireChicken
Time for another STICKY!!!
This is going to be another excellent resource as more and more people post.
How are the spyder 2 express and the Pantone Huey calibrators. Those seem to be the most popular ones in my price range
