Monitor problem ........... ViewSonic A90f (a slight flashing)
CorCentral
Banned
Feb 11, 2001
6,415
Bought this monitor from BestBuy 4-12-02 ........... Also purchased the $50. 3yr warranty ;)
ViewSonic 19" A90f
It flashes bright to dim but it's barely noticeable . You can only really notice it on dark grey or black screens .
It's like you set the brightness up a notch real quick & set back . (bright , dim , bright , dim) . Similar to a low refresh rate flash .
Just noticed it a few days ago btw .
The video card I use is aging (I'm in the process of building a new rig) as it's a GeForce 2 GTS 32mb Elsa .
Anyone have any ideas or have input on premature monitor failure signs ?
Thanks .............
Aug 27, 2002
10,043
if you have the high dollar warranty, just take it back and get a new one ;) it's much easier than worring about what's wrong with it.
CorCentral
Banned
Feb 11, 2001
6,415
I did'nt know how the BestBuy warranty worked ? ? I can just take it back & replace it with a new one ? Sounds too easy to me .
Can I take this one back & replace with the newer A90f+ ?
Anyone experienced in Best Buy knowledge , please list my options :)
