I have an NEC 19" FE950+ (purchased between Jan and June of 2001) which I believe is on its way out
I notice it more at higher resolutions, but its apparent in all resolutions/color bits/refresh rates. It is the most noticable with text. My screen seems to wiggle horizontally.
I want to make sure before I make a big purchase to replace it.
My video card is an ATI RADEON 9800 PRO (purchased in the last 2 months). I have been running my video card with no fan for the vast majority of its life (using a Zalman 80C-HP [with no fan]). My case is an Antec Sonata (with 2 120mm Fans [one default case fan and one Enermax Adjustable]). I have a Thermalright SLK-900A with a Panaflo 92mm Medium Output w/RPM on my CPU. Additionally, I have a Zalman ZM-NB47J Northbridge cooler.
I don't know what the inside temperature is, but it seems very cool. I can place my hand on the Zalman video cooler and its not warm at all.
I attempted to plug my NEC 17" XV+ into the primary video connection on my ATI card an no problems, but no matter which connection I plug my NEC 19" FE950+ into, it has the same symptoms.
So, is my monitor on its way out?
