Modular PS cable
Seekermeister
1,971
The one thing that I forgot to order, is another modular molex cable to connect some upgrades. I can order it from Antec, but that would mean another delay waiting on it. I searched CompUSA for this and found nothing, but then I'm not sure if I used the right keywords. I'm sure that it varies from one area to another, but is there a national chain of stores that I might find this locally?
Seekermeister
1,971
Thanks, but I already have some adapters that I could use. But, I have so many components plugged into the 2 molex cables out of the PS, that I thought that I should have another to prevent any kind of overloading. But, then I don't really know what the internal distribution in the PS is. There is 2 12V rails, but do these go to all of the outputs at once?
John
Moderator Emeritus<br>Elite Member
4
If you have a modular psu then it should come with the necessary modular cables so that there are not any exposed connections where they connect to the psu chassis. There are a lot of multi-rail psu's that are actually single railed units. A lot of dual rail psu's claim to have the 12v1 going to the 4 or 8 pin +12v lead for the cpu and the other rail for everything else. There really is no standardization that all mfg's follow and it's annoying IMHO.
Seekermeister
1,971
It only came with 2 molex cables, 2 SATA cables, 2 PCIe cables and, of course 1 ATX cable. Since I don't use PCIe or the second SATA cable, that leaves 1 PS connector open.
Old Hippie
6,361
Can ya link to the Antec piece? That may give more ideas.
Seekermeister
1,971
I doubt that would help, because it was only a text link, without any pictures. I wasn't 100% certain which cable to order anyway. One was called an aux connector with cable, and another was called a molex connector with cable. They both sound like they are for the same purpose.
EDIT: Unless "aux" is what those little connectors like that goes to a floppy is called?
Seekermeister
1,971
Right now, I'm thinking about cutting the connector off the PCIe cable or the SATA cable, and attaching a molex connector...if I can find one?
EDIT: Even this wouldn't be too great, unless there are molex connectors that can be attached mid cable. I have some SATA connectors that do this, but I haven't seen a molex connector like that.
Old Hippie
6,361
Should be some here.
It sounds like you are wanting something that plugs directly into the PS itself. I have 3 different modular PSs, and all the connections to the unit itself are different for every manufacturer.
Seekermeister
1,971
I may have to resort to something like that, but I was hoping to find something locally, to avoid the delay in ordering. Since I only use money orders, it takes around 2 weeks to receive anything from an online order.
