Absolutely. The only thing AWD does is allow you to accelerate into the ditch more quickly than you could with 2WD. Most people don't realize that AWD does not help a car stop any better since all cars already brake with 4 wheels. More people would benefit from putting snow tires on their car than getting AWD.
that is not entirely true.
if you took a curve in an awd car say in snow, you probably would be less likely to lose traction, so you'd have better control of your car if you entered at the same speed. so you wouldn't have to hit the brakes as early, or say fishtail a rwd car on a curve. i mean it would probably still not be the smartest thing in the world to do, but you would probably be more likely to be able to get away with it in an AWD car.
of course once you do slip, or have to stop then you are just as bad off as a FWD or RWD version of your same car (probably worse off as your brakes would have to make up for the mass of your AWD system)
