yes it undervolted ~ but its v-regulation system was great, only dropped .02-.03v under load :QOriginally posted by: PhoenixOfWater
THUGSROOK -
Did you find that the Abit BE7 was under volting?
It looks like the Albatron PX845PEV Pro under volt by .02 to .04 volt
Originally posted by: oldfart
There is always 1:1. I think it is the auto setting. Albatron and Gigabytes ratios are a little different than the norm
1.5 = 4:3
2.0 = 1:1 (or auto?)
2.5 = 4:5
2.66 = 3:4
Interesting. Maybe it looks at your ram SPD and determines if it can run 3:4 @ 100 FSB? I'd rather just have manual control like Asus and Abit have.when i use auto it give me 2.66
Originally posted by: Zap
Here's something to try... do a pin mod to your P4 so that the motherboard thinks it is "officially" a 533MHz FSB CPU.
http://duh2.brawleyonline.com/computer/fsbpinmod.html
Strange... should work, but I've never actually tried it. I tried nail polish on socket 370 CPUs (the Tualatin on BX) and didn't have any luck, so ended up breaking pins, which worked. Dunno. Maybe I'll try it with a Celeron 2.0, not too expensive to sacrifice.
Originally posted by: render
How come this board doesn't have 1:1 memory ratio?
I oced 1.8a and memory automatically set up at 354. I can't oc more because of PC2100 memory I have.
