gsellis
- Dec 4, 2003
- 6,061
- 0
- 0
DV-AVI is about 13GB/hr of video. That is why I have 1TB+ on my editor. And yes, encoding takes awhile. It would take about 6 hours for my similar machine to yours to encode a 1.5 hr DVD. I did a encode and burn, single pass, on my workstation last night inside Avid Liquid for 1.5 hrs of material. It took 2 hrs. With lots of horsepower and a good encoder, good quality can run faster than real-time (30 frames in less than a second). But at Best quality, dual pass, variable bit rate, even my workstation takes about 5 hrs for 1.5 hrs of material (that is VBR avg 8200kbps (peak 8500) with AC3 Dolby Digital).Originally posted by: redgtxdi
OK, so I tried DVDSanta and while it did *do* the job, it didn't handle the video/audio very well. The sound was full of flickers and the video frame rate got worse as the video went on.
Soooooooo.......
I tried to conver the .wmv file and it seemed to do that well. But since the .wmv file was only about 400mb long, I decided to let Windows Movie Maker create a DV-AVI file and then let DVDSanta convert the file. As a DV-AVI file it was a little over 5GB (YEOOOWWW!!!).
DVDSanta's doing the conversoin right now. It's 16 minutes into it with 12 minutes left to go.
I dunno if a more powerful system could do it better on the fly. The machine I'm doing it on.....(only 'cuz it's the only one with a firewire port)........
Celery 2.4
512mb
200gb 7,200rpm HD
ATI 7500 AIW card
I have an extra P4 2.8Ghz layin' around I could throw in, but I dunno if that would allow this system to do it on the fly or if it's just a prob w/ the software. (shrug)
Now you have discovered the one thing that really still taxes even modern computers above and beyond new games
