TheLizardMan
here are my current specs...
AMD Barton 2500+@3200+@1.7Vcore (11x200)
Abit NF7-S V.2.0 W/ SLK 800 + 80mm Thermaltake SF2
[Bios] nf7d20 - Hacked
Antec True 550
Buffalo Tech CH-5 PC3200@200Mhz 11-2-3-2- (512x2) Dual Channel @2.7Volts [6/6]
nVIDIA GF3 TI200 Gainward Power Super Hyper Turbo Edtion 128MB (230/487) DET 45.23
Turtle Beach Santa Cruz
Promise ATA/100 Controller Card
Nvidia MCP Integrated Network Adapter
[WD 80GB 8MB 7200RPM][WD 60GB 2MB 5400][WD 60GB 2MB 7200RPM][IBM 60GB 2MB 7200RPM][IBM 40GB 2MB 5400RPM[WD 200GB 8MB 7200RPM]
Lite-On 40x CDR/W
iiyama Vision Master Pro 450
WinXP SP1
If I bought the IC7 would that be a good mobo? whats diffrent between this and the -G or -MAX version?
And if I bought the IC7 and the 2.X with the RAM that I have what type of overclock should I expect to get with no problem?
Last Year I bought the 1.6a and had it at 2.6 with the defult heatsink. Is the default heatsink that comes with the 2.X good enough for an insain overclock or no? what should I expect it to do?
Also... what CPU for the buck is best? does the 2.4 OC past the 2.6? and what version is best? A, B or C?
I might sell my current 2500+ Barton that is at 3200+ and break even with getting a Intel. At stock speed what CPU is better "my guess is the Barton", but at OC speeds the Intel should be faster correct?
BTW... does the IC7 have pci lock? the last Intel mobo I had did not have PCI lock, and that is the reason I sold the mobo.
Thanks!!
Antec True 550
Lite-On 40x CDR/W
WinXP SP1
Thanks!!
