Stg-Flame
What YOUR PC will be used for. Gaming.
What YOUR budget is. $600-$700
What country YOU will be buying YOUR parts from. USA from newegg.
IF YOU have a brand preference. Intel and Nvidia. No Gigabyte (very bad experience every time I've used their products)
If YOU intend on using any of YOUR current parts. I'll be using my old eVGA GTX 670s in SLi. If the budget will not allow for both cards then a single will suffice.
IF YOU plan on overclocking. Minor overclocking - nothing extreme. Although my old 670s are both heavily overclocked.
What resolution. Most likely 1080p as I don't think a budget system will handle 1440p.
WHEN do you plan to build it? Three weeks but since we are this close to black Friday, I'll probably wait until then to buy the parts.
Do you need to purchase any software. Yes, Windows 7 64-bit.
I'm doing this from my phone a long ways from home so forgive me for any errors.
This build isn't for me but for a friend I work with. I know picking parts for a build over a month away is generally a bad idea but I'd like to have a base-line to work with so I know what to expect performance-wise. I have checked out the midrange guide but most of those are from different websites and I'd like to order from just one site all at the same time. If possible, I'd like to set this up for upgrading in the future.
I greatly appreciate any advice anyone can offer.
