I'm tired of people bashing this 960 2GB, it's honestly the best card for $200. It isn't a brick of a card and doesn't hog power. If you don't want/can't spend past that nothing else matters.
Agreed. By extension Intel & AMD should scrap all CPU's except the i7-4790K and FX-9590 because "value is relative" and
"for $50 more you could buy x, and for another $50 you could buy y, and for another $50...", etc. I got to play with a GTX960 recently and it's a great 1080p card, especially for HTPC's.
It doesn't even suck up 100w on Metro Last Light (half that of an 285 so God knows where the R9 290 recommendations are coming from for low-powered, silent optimized i3 HTPC rigs). Many games ran passively (no fans spinning) often at 10-25w lower power draw than even the 7790 / R7 260X (which is impressive as hell considering that card is half the speed, and even 10% slower than a 750Ti).
Serious advice for OP:-
You could "fit" a 200-250w R9 290 into a Mini-ITX but certainly not at same thermals / acoustics. Been there, done that. 90c temps + throttling or (genuinely) quiet acoustics - pick one of two. Temps also increase other components - CPU & case fans run faster, lower wattage PSU's run much hotter & PSU fan runs faster. Real world measured example for a Gold-rated 400w PSU : 150w load = 13db, 200w load = 19-24db, 300w load = 29-34db, etc). Adding +120w from 150w (GTX 960) to 270w (R9 290) increases PSU fan speed by 15-20db (triples to quadruples the noise). Going fanless merely increases the heat build-up in the case. And I certainly don't want my HDD's temps creeping up past 50-55c which is exactly what happens in many Mini-ITX cases when you stuff a +200w space heater just 2cms away from your drive cage. Laws of physics don't cease to apply just because it's an AMD on sale at a bargain. If the case is in some kind of enclosed / semi-enclosed TV cabinet, that can increase localized ambient air temp by 2-3c which increases component temps even more.
I've Just finished helping a friend build a GTX960 based HTPC. His temps dropped 25c on the GPU (87c to 62c) and 8c on other components moving from a temporary 200w GPU to a GTX960 100w card. 2GB VRAM is not an issue if you're smart enough to turn down settings from Ultra to High (which with an i3-4130, you'll probably be doing anyway). Half the time the visual difference is about 5% (if that) for up to 20-40% difference in performance. In a living room, you'll also be sitting further back (typically 8-10ft away) where the visibility of a lot of the more subtle Ultra vs High effects can be even more marginal than from close up (especially during real-world gameplay vs comparing side-by-side static screenshots). Lots of variables but the ultimate key to a silent HTPC is simply to not create excess heat in the first place by buying better perf-per-watt components even if they are at a slight price premium as it causes far fewer headaches & annoyances in the long run.
A lot of the "hate" for this card comes from people projecting their own builds onto others (and obsessing over "figures on paper") with little to no experience of either using the card or building silent Mini-ITX HTPC's. The OP specifically stated "
low power use, low noise (fan turning off when not needed is a huge plus). Also, $200 is a good price for me and i wouldnt need to upgrade my corsair 430w ps" yet people have ignored his needs and demand he buy what other people want instead. Hopefully the AMD 300 series will bring much higher perf-per-watt (and lower wattage cards) to the table to both put pressure on nVidia to lower prices, but also to end the inane "
220w dGPU's are the best option for an ultra-quiet Mini-ITX HTPC rig!" 'advice' that's been doing the rounds since the GTX 960's release from those who cannot understand "bang per buck room heaters" are not everyone's priority, the reason people build "medium-weight" hybrid HTPC/gaming rigs for the living room is not "
I want a 500w top-end PC but can't afford it", and many are quite happy to pay a premium for lower heat / noise components (like 1TB SSD's instead of HDD's to eliminate any mechanical case noise / vibration) without needing to be being labelled "nvidia fanboy" every 5 seconds...
To OP : Ignore the hate & the haters. If you want a GTX 960, buy one. Or you could wait and see what AMD's mid-range 300 series brings. Either way, avoid putting +200-250w GPU's into small low-airflow cases with 400w PSU's like the plague.
