Microphone static sound.
darkconz
69
Hi there,
I am using a Acer TravelMate 8104 with Audigy 2 ZS sound card. When I plug my mic into the mic input and try to record something, there is some static sound. Could it be my mic or is there some setting that I must change? I used the same mic at home on my desktop and it worked perfectly fine.
Thanks in advance for the help.
CrispyFried
1,122
loose plug? maybe the input level is too high (distortion?). is it only static or is it static plus the voice? what kind of mike?
darkconz
69
Its a generic mic but it works fine with my desktop. When i record anything, there is a buzz sound in the background.
corkyg
Elite Member | Peripherals
27,370
240
Sounds to me like an impedance mismatch.
