Mic problems
DemonEdge
105
I recently got a new logitech cheap headset but i realised yesterdasy the microfone isnt working properly. My headset uses two plugs, one for the sound and one for the microfone, coloured black n pink respectively. Now I onticed on CS my mic was getting insane static and was unhearable. I have tried turning up volume in settings e.t.c but its still ******. I tried unplugging + replugging, even into other sockets but to no avail. I then pluggfed my old headset's micrfone (which definately works) and that wasnt working properly too, so it could either be the microfone socket (which I doubt) or some settings on my computer.
Any help?
PurdueRy
13,837
4
1. It's microPHONE
2. Try looking in sound and audio devices, I know there is the option for a 10dB or something boost....turn that off if its on
DemonEdge
105
well i go to what u said and i find the sound recording section with Realtek AC97 Audio set as the sound recorder. The only options I have are volume (which is on full) and advanced which is blanked out and unclicable.
PurdueRy
13,837
4
go to the volume tab, click advanced, go to options, properties, select recording, click ok. click advanced on the microphone input. See hwat is selected there
DemonEdge
105
after i go to volume and advanced only one window comes up with some bass options (which i cant edit becos it doesnt supoport them) and some 1 mic boost option, which was ticked. I unticked it but no change.
