Originally posted by: feralkid
Originally posted by: BarneyFife
Hire more guards along the border, arm them with machine guns, and let the Mexicans kill each other in their country.
Lame supply side argument. :thumbsdown:
Death penalty for any amount of coke or meth possesion in the U.S.:thumbsup:
Why meth? It's as addictive as pot with 1/12th of the half life.
Amphetamines are not physically addictive drugs and about as psychologically addictive as alcohol or pot.
You are absolutely retarded and have never met anyone who is addicted to tweak. I just lost any and all e-respect for you. Seriously, are you that dim?
Edit: Ah, UK. That explains alot.
neither meth nor pot is physically addictive
Methamphetamine is addictive, and users can develop a tolerance quickly, needing larger amounts to get high. In some cases, users forego food and sleep and take more meth every few hours for days, 'binging' until they run out of the drug or become too disorganized to continue. Chronic use can cause paranoia, hallucinations, repetitive behavior (such as compulsively cleaning, grooming or disassembling and assembling objects), and delusions of parasites or insects crawling under the skin. Users can obsessively scratch their skin to get rid of these imagined insects. Long-term use, high dosages, or both can bring on full-blown toxic psychosis (often exhibited as violent, aggressive behavior). This violent, aggressive behavior is usually coupled with extreme paranoia. Methamphetamine use can also cause strokes and death.
http://www.drugfree.org/Portal..._Guide/Methamphetamine
Methamphetamine
Methamphetamine is a highly addictive central nervous system stimulant that can be injected, snorted, smoked, or ingested orally.
http://www.whitehousedrugpolic...amphetamine/index.html
Seriously though, arguing if Meth is addictive or not is like you saying the Earth is flat and me actually responding.
I used to appreciate your service, but now you are either a troll or are so brainwashed by your 2nd-rate military that you dont know what to do. Brush your teeth.
No, it is not physically addictive and none of what you posted nor what you linked to says it is.
Methylated amphetamines are just that, same as any other amphetamines only they last longer because of the longer chain.
Meth is NOT more physically addictive than alcohol (which, while completely different, shares some of the properties, like needing higher dosage, so does pot by the way) or pot.
There is no receptor regulation and there is no bodily storage, you might crash for a day and go through the same withdrawal as an alcoholic (although not as bad) but that has nothing to do with physical addiction.
MDMA is another form of amphetamine, while structurally different it's basically the same drug with a different delivery system, so is ritalin, would you say ecstasy is addictive or ritalin?
In reality ALL drugs are addictive in some way, even psychotropics, but very few are physically addictive, some are like nicotine, Opium (and derivatives) and cocaine (in various forms).
Now peyote though... that's just nice.
