Originally posted by: OS
Originally posted by: KEV1N
IM me? 🙂 And let me know the overall process / accessibility of the components? Did you use 5w20? What filter?
Well, for any oil change, it's pretty much drain, replace plug, replace filter (remember to put oil on the gasket of new filter), fill up how much the manual says to and then check dipstick.
For the I4 engine, the oil filter is on the back facing the the firewall. I don't know where the filter is on the V6.
I used castrol 5w-20 GTX and a honda OEM filter. If you buy your filters from honda, make sure they don't say "by fram" on them. If they do, give them back.
Sorry, I'm a n00b here. I've decided I will do all my oil changes myself on this car.. did you jack up the car or do you have ramps?
Yeah actually I've driven the car hard a couple times and in retrospect I probably should have waited until atleast after the first oil change just to be extra safe.Originally posted by: RagingBITCHIt's a brand new car - it's recommended by a lot of people to do so after the break-in to get the metal shavings outOriginally posted by: IBuyUFO you're not supposed to change the oil until 7,500 miles doing normal driving or 3500 under stressful conditions
Originally posted by: jjsole
I would assume once they are caught in the oil filter they will stay in the filter, especially shavings which would have a helluva time getting thru the filtration.
Well it's not so much for the shavings but the particles that you can't see. Hopefully the filter was good enough to catch everything that matters but sometimes it takes more than one pass to catch a particle that can cause wear. It's probably fine but for the extra anal retentive and stuff. 😀
When I changed the oil, it was pretty much cooked black, even at only 2500 miles.
I didn't have to jack up the car, I just reach under to open the plug and then pull out the filter from the top. Yeah some cars you pretty much have to jack up. If you need to jack up your car, you should get jack stands. Remember to pull up the parking brake before you jack anything. :Q
I really recommend you get someone knowledgeable to watch over you the first time. Don't want to do anything stupid to screw up a 25K car.
Visit v6p.net for a late model accord forum to putz around.
