Originally posted by: Renob
munruss I was a painting contractor for 15 years and if you want to strip them use Jasco Epoxy and Paint stripper it will make easy work of removing the paint, but be VERY careful it will eat your skin off. be sure to use safty gogles and buy a nice 1and a half inch putty knife to scrape with
Its a jell so buy a few cheap brushes to put it on with and put a nice thick coat and in a few minutes it will start to bubble upl, dont scrape to early let the jasco do the work.
Also if the paint is in good shap just sand it and paint over it.
commonly sold as goof off
Goof off is not a stripper, it is used to remove spots of paint.
munruss do not use solvents to remove paint like OrganizedChaos is saying, as with any job there is always the right tool.
