I'll fix it for the low, low price of $1999. If I can't, then you get back $999. (That is 4 years of inflation from the $495 price!) 😉
Seriously, you dug this thread up from the grave via using a search engine, but you can't use the same search engine to find a data recovery specialist?
If you are looking to do it for free, then, it depends on the damage of the device, and since you did not included any pictures of said device, nobody here can tell you anything except use the same search engine to find a data recovery specialist.
