Why do "they" recommend that the paging file be 1.5x as big as the RAM? That's counterintuitive... and now we have people wasting 24gb of hard drive space on a paging file.
Or worse yet....Wasted SSD space!
so how about that pagefile.sys that ran away? 😛 anyone know where to find that bastard?
Hes not in my task manager resource monitor, C drive or anywhere i look
Are you certain that you have all hidden files shown and enabled? You will know this if you see file extensions like .exe on programs, and see two "desktop.ini" files on your desktop.
I've heard that Windows 8 does not use this approach of simple-minded "use 1.5x" and I need to actually check my other computer running Win 8 on an SSD - I have 8 GB of RAM and an SSD on that system, so I wonder what size Windows 8 chose for the pagefile? Will report soon...
I set mine to 1GB-min 1GB-max... BAM done!
I have been around computers since my C64 and Tandy Coco and from the first time I heard that "rule or sugestion of 1.5x the Ram size" I was like that is the Dumbest thing I ever heard!
Like you said....the Paging file is supposed to be used when ram is not available so wth do you need it to be bigger the more RAM you have? It is so dumb and lacks any type of logic.
On the contrary, you will need less paging file the more RAM you have not more.
Gotta love when something like that is repeated for years like it was the gospel 😀
can you help me find my missing pagefile.sys ?
Press Win+break to bring up system settings.
Click advanced system settings to bring up System Properties
Under "Performance" click settings
Click the tab for "Advanced"
What is shown under Virtual Memory? Click the button Change...
What is shown? Is it automatically manage paging file? Is it Custom? Is it set to No paging file?
Feel free to uncheck the box for Automatically manage, and check the box for custom size. Enter 512 for initial size and 512 for maximum size.
Reboot to establish these changes and create a 512 MB pagefile and save a bunch of space on your drive.
3072-3072 is my page file size, not automatically set
no pagefile.sys in my performance monitor or C:\windows
My pagefile.sys in 7 is in the root directory of C, and I have to uncheck 'hide protected operating system files' in folder options to see it.
Interesting, but I look at the silver lining to this cloud and see opportunity!
I would suggest setting your system to not use a page file at all. When you set that, the computer will ask you to reboot.
After rebooting, go back and set it to 512 MB. That will free up 2.5 gigabytes of space for your use, and will also ensure you actually have a pagefile.
