- Jun 21, 2005
- 12,066
- 2,279
- 126
Got a Kill-a-Watt meter and just wanted to see what the power draw was. Here's the full specs of the comp:
E6400@3.4GHz With Thermalright U-120 with 2x120mm fans
Gigabyte DS3 with Thermalright HR-05 NB heatsink using 1x80mm fan
8800GTS (650/1000)
1x15k rpm SCSI drive
2xSATA HDDs (1 HDD with a Vantec Vortex HDD cooler)
1xexternal DVD writer
Antec P180 with 3x120mm fans
OCZ Powerstream 420
Soooo....with all that, and running RTHDRIBL, it was measuring about 350 watts. Phew...seems like I'm nudging up against my PSU capacity.
Also, just running Orthos to load the CPU, it went to about 315 watts.
At full idle it's about 265 watts. The idle is higher than I was hoping but I guess with all the OCing, it can't be helped.
8800GTS (650/1000)
OCZ Powerstream 420
