I Just purchased a New ADATA S599 128GB. (How do I find out what version the firmware is?)I had my Win 7(64 Bit) HP O/S and all my software running perfectly on a Kingston Series 2 SSD 128GB using ACHI and Trim enabled. So using Acronis 11 I backed up entire drive including MBR onto a HDD then I loaded the Acronis recovery software and restored all data including MBR to S599 removed Kingston then rebooted. On Post I get message BootMGR missing Ctrl ALT delete to restart. Would not boot no how no way. Replaced Kingston drive rebooted then tried cloning the SSD to new drive. Same results. Bootmgr missing. Used Win 7 repair disc both times to repair startup. All time it fails same message bootmgr missing. With ACHI enable I tried a new win 7 install, complete with loading ACHI drivers from Gigabyte(GA-X58A-UB3R MB), still get same results. I should mention in all cases I can boot to this new drive as long as the Win7 disc is present in the drive and repair filles are loaded. Anyone know what's happening? How can I tell if I have the 100MB Windows reserved partition. Thanks in advance I have spent 3 days at this and I should mention I tried all the same procedures using IDE
