- Feb 15, 2011
- 2
- 0
- 0
I have a newer MBP 13" (Intel Core 2 Duo, 2.4 ghz, 4 gbyte 1067mhz RAM, OS 10.6.6) laptop purchased about a year ago in which I installed a Kingston SSD NOW V+ series 128 gbyte drive. All seemed to be well until three months ago.
The MBP would occasionally lock up the sound port and then the cursor. I used AppleJack to repair the preferences file to restore performance. Now I am also getting an invalid file size error and AppleJack will not repair it.
I need to use disk utility from the original install disks in order to restore operation.
The major clue which indicates an SSD problem is taking longer than 12 seconds from turn on to user screen. When rotating cursor is present longer than thirty seconds I know it is time to fix things...
Could the SSD be going south?:
