Quote "I am running an athlon 1.2 ghz (non-overclocked, due to motherboard limitations)
So, I got the chrome orb (
http://www.thermaltake.com/).. Webpage says it supports up to 1.3 ghz.. However, I am getting close to 60C or 160F.. Is that good? The numbers look scary"
I can tell you that Chrome Orb will not support 1.3G up front.
1.3G processor has 71W. C/W for Chrome Orb is 0.81c/w
AMD calls for 42C ambient temp inside the chassis.
Under full load, the CPU temp will rise 57.5C (71W * 0.81C/W = 57.5C)
57.5C + 42C = 99.5C
Maximum core temp for 1.1, 1.2 1.3G processor is 95C. Chrome Orb will miss the AMD Spec by 4.5C.
1.2G is 66W processor. Use the same calculation, the temp under full load with 42C ambient will be 95.5C. Just over the maximum temp!!
But this does not mean you will fry your processor. If you keep your ambient temp inside the chassis well below 42C, you can still get away with your existing setup.
