Max speed air cooled?
AMD 1.2 Ghz Axia overclocked to 1.35 Ghz(10x135)
stock retail HS/FAN
default voltage also
ASUS A7V133 Motherboard
Antec sx830 case with 4 case fans, power supply fan and a pci slot fan
crucial cas 2 PC133 sdram
let me know if you want any other info 🙂
What system you talking about - AMD or Intel, or you just curious how much ppl can get out of their systems with air-cooling? 🙂
using a Gorb and a 120mm fan blowing in over the vid card and MB , case sides off check out my rig for details
well my best air oc in % is my slot A 550@1080 1.9vcore with an alpha p7125 with dual deltas and 1 ystech + a 20cfm 50mm fan on the back and a total of 38 fans in my sys couting fans on all sinks and both psu's, a few mods were done to the asus k7v like sinking the clockgen and some voltage regulators, and the highest oc i did with air was a slot A 850 to 1143 with same casee and mobo. May the 850 rest in peace it died when i remove the heatplate to see the core speed witch was 850 i guess i had poor contact or just crushed the core a bit making it fragile and the core for the 550 is unknow till it dies cause i aint risking this chip hehe almost a 100% oc out of it hehe, maybe get the 100% if i ever go water cooling
AVIA "Y" T-Bird 1300@1500(116x13)1.75v
MSI K7T Pro2-A
Copper Gladiator HSF W/Delta
Arctic Silver 2
256 Megs AVL PC-133
Visiontek Geforce2 GTS 64MB DDR @220/420
8x8x32 CDRW
52x CD-ROM
40 GB Samsung HDD
D-Link NIC
Antec SX830 Case W/5 Fans
300 Watt Antec PS
TBird1.33@1.5@1.75V (143*10.5)
ALPHA PAL 6035 with adapter and 26cfm 80mm fan
Asus A7V133
SX1030 with 4 19cfm case fans
850@1Ghz (AFFA Athlon)
Thing is, I'm not heat limited at all. I have the same limit w/ my case fans on as off (15F CPU temp difference, I have lots of case fan action). The cooling I had could probably suit an AXIA over 1.5GHz.
Tbird 1200@1470. Goes up to 1554 stable though, just gets a bit warm. Using a Thermoengine w/Delta 38CFM fan on an Asus A7V133
Here is my hot (litereally), air-cooled system:
AMD 1.2 Ghz Axia oc'ed to 1.35 Ghz(10x135), just got it, needs to play around a bit more
Thermaltake Volcano II cooler (not the best I know, but it was the best the shop had)
Uses the default voltage as my system is too hot in my cabinet to allow higher temperatures
MSI K7T Turbo Limited Edition Motherboard
512 mb SpaceWalker PC133 sdram (2x 256 mb)
A noname, very slim case (which gets very hot, plan to replace it as soon as possible)
A single case-fan in the front (plan to get more with a new case)
Any recommendations about which case to buy? (it is really hard to get more "special" things here in Denmark though 🙁)
check my rig link for details I typically run it at 1507 stable but have had it up to 1540 seemingly stable although the temps made me nervous
Hey, I would go higher but my GA-7DXR came with a problem so I had to RMA, the problem kept me from setting VCore, but the overclock is testament to how awesome the AXIA's are! The temps are Bios and after flasking AMD optimized, the only true 100% test that I know. All at 1.75 standard:
1GHZ@1.4 at 1.75 (AXIA week 9)
OCZ gladiator w/YSTech 26CFM fan and two Sunon 120mm fans, one blowhole and the other across form the motherboard. AS2 of course. Temps get up to 52C, never higher, but that is hot. I probably shouldn't go any higher, but I refuse to use the delta instead of the YStech. The Delta I have would do a much much better job, but I would rather water cool. I am sure that the CPU can go much higher, considering what it is doing at 1.75
Reasons I have been blessed:
1) My 256MB crucial ram is at CL2 (instead of 2.5, and runs FSB 158 at standard voltage, 168 2.7V
2) My proccesor not only takes this 40% OC at standard voltage, I also chipped the die! It works
3) I got a scholarship
No luck with love though...hehe, I like computers too much I guess. Peace
axia week 12 1gig, kt7a abit, rev2 256mb mushkin, ata100 ibm 15.4gb hdd, nvidia gforce2 gts leadtec, sblive value all in an addronics tower. OC w/hedgehog @ 1358.5(143x9.5) now watercooled
@1554(148x10.5) a little unstable, stable @1502(143x10.5)will soon be putting a copper waterblock on my northbridge chipset also.
<< Here is my hot (litereally), air-cooled system:
Any recommendations about which case to buy? (it is really hard to get more &quot;special&quot; things here in Denmark though 🙁)
The Antec sx830 case I have is a nice case. it has spots for 4 case fans( 2 front and 2 back) also has a spot for a case fan to cool your hard drives. with your better HS/Fan you should do better than i am with my stock retail fan and HS whereas right now I am getting the same overclock as you.
my temps when running Sandra burnin and running three browsers while being online never gets above 58 degrees celsius using ASUS Probe to get temps. my bios shows max 47 degrees with both showing the MB at 24 degrees.
