max payne II settings
0roo0roo
64,795
84
Right-click on the shortcut to Max Payne 2. In the Target: line, add this to the end: -developerkeys (remember to add this outside the double quotes, and remember to put a space before it or it will not work). Run the game, then press f11, then press page up and page down to cycle through the game's character models. theres a surprise along with the fps;)
f3 is camera float.
Confused
14,166
Originally posted by: tjaisv
I just want to see my FPS. My game is here, V:\Program Files\Rockstar Games\Max Payne 2\MaxPayne2.exe
I go to Start => Run => and type "V:\Program Files\Rockstar Games\Max Payne 2\MaxPayne2.exe -developer"
but this doesn't work
Put the -developer outside the "s.
Alternatively, download and install FRAPS, it will show you the FPS in any game/app that uses Direct3D or OpenGL
Confused
EmperorIQ
2,003
Originally posted by: aRCeNiTe
*SEMI-SPOILER*
i run the game at that res on a 9700 pro at 6x AA and 128x Anio, and it run's flawless except on the level when you play mona and you're saving max from the fire ^^
Bill
oh no, i'm not at that part yet~!!!
oh well, now i'll look forward to it instead of being surprised
BoomAM
4,546
As its along the same lines;
What are the chances of me running MaxPayne2 at 1280x1024@Max everthing. Smoothly. And again with 2xFSAA and 8xAF?
Rig is in sig.
Regs
16,665
21
Rig is in sig.
It Could. I'm actually running 1280x1024 with 4xFSAA App.Pref. and 8xAF Performance set in the Ati CP. I'm thinking about turning it down to 4xAF just because I haven't seen much image IQ increase with 8x
For you, 4xAF performance will be more than enough. I think 8xAF is pointless in this game at 1280x1024 or above. Just make sure you don't forget in Max Payne's video options to set Texture Sharpness to max, not just the opening dialogue box.
FFactory0x
6,991
I run Mac settings no aa @ 1024x768 and its usually around 85fps and drops to 60 for a split second some times
9700 pro
2100@2.3ghz
512mb twinmos
BenSkywalker
67
I cant agree with that since Max Payne 2 offers great physics and greatly designed enviroments. You also need to remember that 3Rd Person games need to draw more on the screen since the camera offers more of a view of your surroundings, while a First Person shooter only needs to draw the things that are ahead of the player.
Not quite true. In a third person perspective the camera angle tends to be down a bit, allowing you to view your character effectively. Due to this you spend less time drawing things further in to the distance. BTW- There is a FPS mod out for MP2.
makes me wonder why Max Payne is a LOT better looking than Halo....but Halo needs a beefy pc just to get acceptable rates while Max Payne can uber shine on a good pc
Older DX7/DX8 style game build versus a DX9 style game build. Halo was built to run on fixed hardware, as such they decided to exploit the features of the hardware heavily and relied on pixel shaders for a very large part of the visual flair their game has. Disable shaders on Halo and your framerate will likely more then double(sometimes quite a bit more). For non DX9 hardware, Halo is still relying on pixel shaders heavily, something that we have not really seen in PC games much to date(TRAoD being the only other example I can think of).
MaxPayne2 is using a more "old school" style of graphics engine to give an improved version of what we are used to seeing in PC games.
Obviously, MaxPayne2 rather clearly demonstrates that the old school method is a lot less system intensive then the shader intensive games that are going to start becoming more common at some point(when is a good question, but at some point they will).
With HL2 they worked on making a game that looked stunning without shaders, and then used the shaders for a bit more visual flair. Halo looks quite fugly without shaders, it needs them(being fixed function platform native, this isn't unusual). Doom3 is like Halo in that aspect, although they are relying on a very different type of lighting model and less intensive shaders, still a massive departure from the older style of games, but not the same path that Halo takes quite.
If Halo were PC native it would almost certainly have better looking 'fall back' visuals, something that MP2 and games of that type do.
Bovinicus
3,145
Originally posted by: shady06
would i be able to run MP II @ 1280*1024 w/ 4x AA 8X FSAA with the rig in sig? thanx
I suggest trying these settings and seeing what the results are. Despite what other people say, you might have higher framerate standards for what you consider smooth gameplay.
GrumpyMan
5,780
265
I have a 9700 Pro at 400/354 and run the game at 1024 X 960 all settings maxed with 4X - 16X. It runs and looks so fine it's amazing. Even Halo runs fine as long as the AF and FSAA is set to application preference and I have no shadows on which I don't care about. No slow downs whatsoever and it looks great for me.
tjaisv
Banned
Oct 7, 2002
1,934
f3 is camera float.
worked, thanks. :)
tjaisv
Banned
Oct 7, 2002
1,934
Confused
Thanks for the FRAPS link :)
BoomAM
4,546
Thats a first. Someone considering other peoples fps viewing "capibilites". Well done there.
Anyway. As long as its over 30fps im happy. Im the sorta person that if a game has a FPS lock (like VC), then i`ll have it on. I can see the difference between 30 and 40, 40 and 50, 50 and 60, and so on upto about 110fps. But i still find 30fps more than acceptable for gameplay.
