Math Puzzles *UPDATED*
Originally posted by: Vertimus
Originally posted by: whitecloak
1/4
series 1 : 1/2 +1/4 + 1/8 + ...
series 2 : 1/5 + 1/4 + 5/16 + ...
Nope. Your second series doesn't converge to 1.
it seems to converge.
1/5 + (1/5)/(4/5) + (1/5)/((4/5)*(4/5)) + ...= (1/5)/[1-(4/5)] = 1
1/4
bah. I suck. found out the mistake.
Originally posted by: chuckywang
9) (sqrt(5)-1)/8
Can you provide a short explanation please?
Hah, I would think with an answer that random that if it were right, I knew what I was doing.
Anyways, if 1/8 is the third term and r is the ratio, then 1/(8r^2) is the first term. Therefore, 1/(8*r^2)/(1-r) = 1. This simplifies to a cubic equation, and you know that one of the roots is r=1/2 since 1/2+1/4+1/8+...is one of those sequences. The other two roots can be found using the quadratic formula. Only one of them is positive and less than 1, that being r=(1+sqrt(5))/4, so the second term is 1/8*4/(1+sqrt(5)) = (sqrt(5)-1)/8
9) (sqrt(5)-1)/8
Yep, good job! :beer:
10) 54
I need a explanation before I can accept any solution. Please read the first post.
This one is harder to explain, but I'll try to explain the main points.
First of all 2004 = 2^2*3*167 is the prime factorization.
Note that for the prime factorization of any number: p1^a1*p2^a2*p3^a3*...., there are (1+a1)*(1+a2)*(1+a3)*.... differenct divisors of that number.
Therefore, if you want a divisor of 2004 to have 2004 different divisors, then those numbers must have the prime factorization of:
2^a1*3^a2*167^a3
and must it must be true that (1+a1)*(1+a2)*(1+a3) = 2004.
Basically, how many different ways can you multiply three positive numbers to get 2004, and ORDER MATTERS.
Running through them all, you can count 54 different ways.
Actually, it basically was counting.. You may call it cheating but I just wrote a simple script to do the work for me. Mathematically speaking, meh.
Edit: BTW, that was my 2^7th post. 😀
1359?
Explanation? For which problem?
oops. for problem 11.
remove numbers which have 3 different digits and 4 digits from 9999.
I think you need to explain more 😛
Number of possible 3 digit numbers with 3 different digits = 10*9*8
Number of possible 4 digit numbers with 3 different digits = 10*9*8*4 (4-takes care of the ordering)
Number of possible 4 digit numbers with 4 different digits = 10*9*8*7
Total numbers with more than 2 diff digits = 8640
Total numbers with less than or equal 2 diff digits = 9999 -8640 = 1359
1359?
1359 is incorrect. I don't have time to say why it's wrong, since i'm off to dinner.
