Math Problem: You have 2 pipes...
3.9A+5.9B=212
(212-5.9B)/3.9=A
3.9((212-5.9B)/3.9)+5.9B=212
All the variables cancel. Thus, B can be any number. Any whole number in your case.
Now it's just a matter of finding out which value of B will give you a whole number value of A. How the fsck would you do that? I'm honestly not sure, but I'd just brute force it.
Originally posted by: EyeMWing
3.9A+5.9B=212
(212-5.9B)/3.9=A
thats what i woudl have done from the start, taken 5 min max
3.9A+5.9B=212
(212-5.9B)/3.9=A
Yeah, ANYONE could've brute force it :roll: I wasn't asking to brute force it. I'm sure a prof will accept it in a test :roll:
3.9A = 212-5.9B
5.9B = 212-3.9A
5.9B = 212-3.9(212-5.9B)
5.9B = 212-(826.8-23.01B)
5.9B = -614.8-23.01B
28.91B = -614.8
B = -21.265997924593566240055344171567
You have the wrong answers. :-D
Originally posted by: MercenaryForHire
Originally posted by: pray4mojo
Need 2 equations since there are two variables.
Originally posted by: ndee
OK, what's the 2nd equation smarties!
Were either of you two dumbfvcks paying any attention in high school? Jesus!
Paging Kelvrick to add a few more dumbasses to his list!
- M4H
Nope but I'm sure you did.
3.9A+5.9B=212
(212-5.9B)/3.9=A
my profs did, if just wrote brute force down and then list the values i tried till i got the answer
Originally posted by: Lord Evermore
3.9A = 212-5.9B
5.9B = 212-3.9A
28.91B = -614.8
LOL 😀
3.9A = 212-5.9B
5.9B = 212-3.9A
28.91B = -614.8
His answers work.
: ) Amanda
My god. What are you in, elementary school?
3.9A + 5.9B = 212
Solve for A and B.
- M4H
there's more to it than that, and if you weren't so concerned w/putting someone down maybe you'd see that. A and B are integers so your wonderful equation doesn't answer the question.
The only reason his equation works is that they ARE integers..if they were just real numbers, he'd need two equations.
3.9x + 5.9y = 212
4x + 6y = 0.1x + 0.1y + 212
0.1(x + y) must be an integer
x + y must be a multiple of 10. I suppose that helps with the guess and check method, but I still don't see a direct way to the answer personally.
Originally posted by: Kelvrick
B = 32
EDIT: I just did it using hte MSN search. 😀
no you did not. all you proved is that you cant read
from the OP
I have the answers(12 A-Pipes, 28 B-Pipes)
3.9A+5.9B=212
(212-5.9B)/3.9=A
Uhm...all that comes out to is 212=212. 🙂 What's the point of even doing that?
To prove that A and B can be anything. Just in case.
Also, this is a common SAT-type problem - there is nothing in arithmetic=>Calc I that can be used to solve this handily.
B = 32
from the OP
Explain it without Brute Force. I have the answer here but I can't follow/understand it.
B = 32
from the OP
It seems he edited his post before I ever entered the thread. I see no mention of 12 or 28 anywhere in the thread aside from your post.
EDIT: Arggh,t hey're in the original post. Fine! I just woke up, ok?!
B = 32
from the OP
look at the first post dude
Oi.
I have one word for you all. The BS-callers, those insulting my intelligence, and those trying to solve it via conventional algebra. Just one word.
GRAPH.
Thank you.
- M4H
B = 32
from the OP
Umm, look a little harder at the OP. I've even quoted it below for you. This is the OP as of the time I'm writing this reply (bold added by me).
Pipe A: 3.9meter
Pipe B: 5.9meter
How many of each do you need to make a 212meter long pipe? You cannot cut them, meaning you can only use whole pipes. I have the answers(12 A-Pipes, 28 B-Pipes) but I don't understand the way. Can maybe someone explain it step by step?
Would be great, thanks in advance!
JW
Oi.
GRAPH.
Thank you.
- M4H
Why not just do it, and show everyone that you know what you are doing. You keep calling people idiots because they don't know how to do it, yet you have posted no proof that you do.
: ) Amanda
I'm actually trying.
3.9A + 5.9B = 212
divide by 3.9A
1+5.9B/3.9A = 212/3.9A
subtract from both sides
1=212/3.9A-5.9B/3.9A
reduce the equation with like denominators
1=(212-5.9B)/3.9A
And that's as far as I get.
Of course that's a long way to go to get back to nothing more than:
3.9A = 212-5.9B
I've been trying, but I believe my math in that area is rusty, so I keep making weird little errors. Arggghe I shant stop till i solve it!
