LumbergTech
this thread must be immortalized.....hilarious how such a simple problem can confuse such as large group
If you cut along the 6" side you will end up with two 6x6" squares, not two 3x12 boards.
To get 20 min total he cut the other 6x12 board not the 3x12 board as you have done.
What, lol. Are you serious, lol.
I have one 12 x 12 board
First cut produces two 6 x 12 boards.
Take one of those pieces and now my second cut split the board in two. But I will cut the length of the smaller plane, which is 6 inches
At the end I have one 6 x 12 and two 6 x 6.
If I slice the other board I will have four 6 x 6 pieces.
LOL, where you learn how cut, hehehehehehe.
But again this is all speculation because no dimensions were given. We assume the board is like in the picture, but obviously that was not the case. And if you apply this same formula to other case that don't involve board cutting, with a board like in the picture, then teacher is correct.
A lot assumptions.
My wording may be wrong, but the point is that you're cutting into the dimension that corresponds to the shorter side, in which case my argument is still valid.
No, if you cut along the shorter side (so the time is shorter) you'll end up with two 6x6 boards and not two 3x12 boards.
To get two 3x12 boards you have to cut the 6x12 board along the longer dimension, thus still doing a 10 minute 12" cut.
The third cut is still 6 inches. The fourth will be 3.
You are as bad as the teacher. If your first cut gives you a 1m and 19m piece, and the next cut gives you 2x 1m pieces and an 18m piece, why does the second cut take half the time???
Reread the question as I stated it:
"say you have a 20 meter long stick and you're trying to make 1 meter pieces"
To make two 1 meter pieces, it takes 2 cuts totalling 10 minutes of work (5 minutes a cut). Therefore to get the 3rd 1 meter piece, you need a 3rd cut and therefore total 15 minutes. Make sense?
(ignore the fact that if you could cut two pieces of wood at the same time you could techincally reduce it to two total cuts)
You know you are correct, wow. The question never states you are cutting a single piece of board into 3 or 4 pieces. Damn dude, kudos to you. :thumbsup:
Edit**** I don't know though, the question gives you the impression she cut a single board into two pieces. But then it says what if she took another board................................
We need the damn teacher to explain the wording on this question.
This question is pretty straightforward and some of your are making it more complicated than it needs to be. If it took Marie 10 minutes to make 2 pieces then that means she can make 1 piece every 5 minutes. If three pieces are needed then the answer is 5 minutes per piece x 3 pieces = 15 minutes.
A lot assumptions.
Meh, I wouldn't worry about it too much. The question wording is terrible and so if you really wanted to, 15 or 20 could be a reasonable answer. Let's say she's cutting a board into pieces shaped as circles. Then to make three pieces you need 15 minutes since making two circles took you 10.
In the example she started out with one piece of wood. If she was creating circles it would take 20 minutes to make two circles as she starts out with none...
I understand what the teacher wanted, but the teacher worded it in a way where the student was right.
I don't get why people are still having issues with this. You aren't allowed to add any extra information to the problem.
"It took Marie 10 minutes to saw a board into 2 pieces. If she works just as fast, how long will it take her to saw another board into 3 pieces?"
The answer is 20. Her work speed is 1 cut per 10 minutes. Thus 2 cuts will take her 20 minutes. If we followed the teacher's math, it would take her 5 minutes to end up with 1 piece of wood.
Think about that for a second.
It would take her 5 minutes to make 0 cuts. That makes no sense. 0x=5 has no valid solutions. That's it. No crazy wood sizes, no deus ex machina wood cutting lightning bolts, nothing. 0x=5 has no valid solutions for x.
That's the way to treat it, based on data that was given. Do not over analyze on something that never existed or making new assumptions. Plain and simple.This question in isolation was certainly answered correctly by the student.
Uh...
12x12 cutting for 10 minutes produces two 6x12 boards.
Cut one 6x12 board along the 6 and you now have one 6x12 board and two 3x12 boards (three boards total). Half the distance means half the time means an additional 5 minutes.
Cut the 3x12 board along the 3. This results in two 1.5x12 boards along with a 6x12 board and a 3x12 board (four boards total). Cutting it takes half as long as a 6x12 board, meaning an additional 2.5 minutes.
Add them up: 10 + 5 + 2.5 = 17.5. Unless I'm not understanding the dimensions (I mean, I do find it highly odd that everyone is talking about boards and rods as if they are two-dimensional), you're wrong.
Brilliantly done sir. 😀
That would very much qualify to be a valid scenario under classy's line of reasoning.
