The very high end ones were originally designed and marketed for PTs and such, and therefore commanded higher prices. There are some mid range ones now like the hypervolt and similar if you want a warranty / better support. We have one that probably cost around 100 and is modeled off the theragun, has an adjustable angle head, multiple attachments, variable intensity. It's been pretty good for the price.Looking to get one. I've check a few top 10 lists and most cost hundreds of dollars. Some as much as $500.
Checked Amazon and found a bunch around 50-80 and many rated fairly high.
Anyone know something about these things?
This is true, and is what I originally did, but the jigsaws on the market are not well weighted and balanced for use as a massage gun. Honestly with how cheap massage guns are these days, it's smarter to just get one separately from a jigsaw.Forget the massage gun. Have a jigsaw? Get massage adapters for it and you're good to go![]()
You mean recip saw dildo attachment right?Forget the massage gun. Have a jigsaw? Get massage adapters for it and you're good to go![]()
Whatever you use more does the most. Absent mindedly foam rolling or massage gunning will get you the same results. If you know where to target and work on things regularly, and often, and in tandem with static and dynamic stretching, then they can do wonders.Those of you who use these, how do they compare to the foam rollers, if you also do/did that?
I use the rollers sometimes on my legs but I dunno, I haven't felt TOO much benefit from it if I'll be honest. It may all just be placebo for me it's hard to tell.
I've been contemplating getting one of these too but just not sure if it'll be worth it.
Foam rolling IT band, while it feels good, does nothing generally. Now if you're hitting the parts of the quads, hamstring, up into the hip, and glutes, you're generally helping out the connective parts of the IT band. The IT is just too big for rolling and stretching to do much.Yeah I would pretty much strictly foam roll my IT bands and then my hamstrings and quads. It felt good and kinda hurt at the same time, but like, I just don't know if it actually did anything. I wouldn't say I was mindlessly rolling either, i was targeting areas that were bothering me, especially my IT bands. Now that I'm talking about it, they actually do feel better now and don't ache like they used to, but it could also be because i switched up my leg routine for a while and that was when I was rolling em out.
I haven't really used the roller in a while though, like a month+.
I do have some shoulder issues and am wondering if the massage guns targeting the specific area would be helpful. My shoulder has been getting better though for sure but it never really gets 100% which is frustrating.
Yeah my one buddy who is a personal trainer and recommended me try foam rolling my legs, also said to try a lacrosse ball right in the front where my shoulder/pecs meet. However my lazy ass never bought one or tried it out. That is good to hear about it putting more pressure than the lacrosse ball though.Foam rolling IT band, while it feels good, does nothing generally. Now if you're hitting the parts of the quads, hamstring, up into the hip, and glutes, you're generally helping out the connective parts of the IT band. The IT is just too big for rolling and stretching to do much.
Yes, massage guns are great for working the pectoral, traps, lats, and if you have a friend, the back part of your lats. I can usually get a bit more pressure compared to a lacrosse ball
Using a lax ball to release the tissue around the pec is an amazing feeling, especially if you do a lot of internal rotation (using a computer, more frontal plane movements like bench, etc). Best thing I've found to do is release the pec, release the lats (lax ball, barbell mash, or foam roll under armpit), and then do some back activation work with a crossover symmetry or some small change plates. Helps a ton with shoulder pain and instability.Yeah my one buddy who is a personal trainer and recommended me try foam rolling my legs, also said to try a lacrosse ball right in the front where my shoulder/pecs meet. However my lazy ass never bought one or tried it out. That is good to hear about it putting more pressure than the lacrosse ball though.
And while I was typing this out, I just remembered my brother bought one of the high end $500 ones before the knockoffs came out for like $100. I'm gonna try to borrow his for a bit and see if it helps and if so then I'll snag one for myself.
I've found that sometimes it loosens up tissues in a way not expected and if you had been compensating it can make things worse. I generally try not to use it immediately prior to a workout unless I know certain parts of me are very sore.Borrowed my bro's and used it yesterday and today my shoulder as noticeably more aggravated so I won't be getting one myself. I still lifted heavy at the gym this morning and did shoulders, but it was bothering me a bit more than it typically does.
