mandrake and xp pro dual boot question
magneto125
147
I read the faq's but didn't see anything specific to this. I was just wondering whats the best way to do this.
I've already did a dual boot with win 98se and it went ok. Except i have a winmodem on that machine and i
still can't find drivers for it . Anyway i was wondering what would be the best way to partion the drive. I have
xp on it already. Should i just let it install on its own ( thats what i did on my 98 machine)? I think it just
installed its own boot loader so i can switch between which os i want to use. All I want to do is just split the
drive in half for each os. I got a 40 gig drive. I'm using the ntfs file system i didn't know if that would cause
any problems.
Any input would be appreciated.
n0cmonkey
42,936
Just use a recent release and you should be able to install on whatever free space you have available.
magneto125
147
Well when i put xp on that drive i just created one big partition. I think when i did my 98 rig it has a prog on
mandrake to let me change my partitions. I think does anybody else know i forget. It's been a while since
I done it.
Zlash
222
You'd have to leave some unpartitioned free space to install linux on or maybe partition magic will let you resize that partition without losing your info.
magneto125
147
I got partition magic i'll have to try that. I just hope i won't lose any data on my drive. I was thinkin mandrake
let me resize my partition in my 98 machine? I forget though. Does anybody know if it will let me do that?
Blayze
6,152
I just used Partition Magic to resize my NTFS partition and make Linux partitions...
Going to install Mandrake now hopefully it will work.
I would try Partition Magic if you have it.
